Does anyone have any idea why I would have issues running XROAR 0.35 (and 0.35.2), but not running XROAR 0.34?
To clarify, running 0.34, everything runs at a decent speed. But if I am running 0.35, it runs really slowly. ROMs etc are all identical. Have tried reinstalling several times. PC is fairly new spec (i7-7700K, 16GB RAM etc).
Thanks
John
XROAR 0.35 issues
Re: XROAR 0.35 issues
Testing locally (which means Linux), there's no difference in CPU usage between the two. Doesn't mean some defaults changes aren't messing you up under Windows though.
Do you see high CPU usage with 0.35? If so, there are more fundamental problems. But if not, try running XRoar with -C (start a console) and seeing what audio settings you get - it may be that tweaking those helps out.
Current dev branch does eat quite a lot more for GMC emulation, but so far I'm calling that a reasonable tradeoff to get more accurate audio... And that doesn't affect what you've been trying anyway
Hello Ciaran,
as I am experiencing sound problems when emulating GMC inside an MPI with drives, I put the parameter -C and
this is what is shown inthe console:
This is using XRoar v0.35.2
Do you see any problem that could be creating the interrupt sound (spikes) I do hear every time?
thanks in advance
Module init: Windows SDL2 UI
Module init: Windows file requester
Module init: SDL2 video
Module init: SDL2 audio
16-bit signed little-endian, stereo, 48000Hz
3 frags * 1024 frames/frag = 3072 frames buffer (64.0ms)
No joysticks found
Machine: Dragon64 (last)
Loading ROM image: ./d64_1.rom
Loading ROM image: ./d64_2.rom
32K mode BASIC CRC = 0x84f68bf9 (forced)
WARNING: Invalid CRC for combined BASIC ROM
64K mode BASIC CRC = 0x17893a42 (forced)
WARNING: Invalid CRC for alternate BASIC ROM
Cartridge: Multi-Pak Interface
Cartridge: Games Master Cartridge
Cartridge: DragonDOS V4.1 (dir)
Loading ROM image: /XRoar/DOS-ROMs/ddos41dir.rom
CRC = 0x6415f6b9Do you see any problem that could be creating the interrupt sound (spikes) I do hear every time?
thanks in advance
Does the same thing happen just using a GMC without the MPI? Not that the MPI code should be adding too much overhead.pser1 wrote:Hello Ciaran,
Also, you've tried the snapshot builds? They have the new mixing code in, be good to know if there's any difference there.
Hi Ciaran,sixxie wrote:Does the same thing happen just using a GMC without the MPI? Not that the MPI code should be adding too much overhead.pser1 wrote:Hello Ciaran,
yes, I tried the GMC all alone and then using the MPI to access floppies. In both cases sound gets interrupted randomly.
I will download the latest snapshot and try again.
What I can assure is that on real hardware with the mini-MPI, CoCo-SDC and the GMC the sound is continuous without issues
I will make some more tests and let you know the results.
Thanks a lot!
bad news ...
Without the MPI using snapshot 2019-4512-w64 keeps interrupting the sound
And even worse, the bat that with 0.35.2 started well with MPI, now refuses to load the DOS ROM, see messages on console.
Of course XRoar starts the Basic without the Eurohard message ...
Any hint?
Thanks beforehand
bad news ...
WARNING: Please quote strings or escape spaces, auto-concat is deprecated.
WARNING: Hitachi HD6309 support is UNVERIFIED!
No joysticks found
Cartridge: DragonDOS V4.1 (dir)Thanks beforehand
I have tested w32 of this last snapshot and later w32 of v0.35.2 and both have the same sound issue
for maybe it was a Basic issue, I have coded the very same in assembler and tested in more than twice!
Same result that I got with the Basic version.
I attach here the source code I have used, maybe someone will find a flaw ...
- GMCTST01.ZIP
- (1.11 KiB) Downloaded 135 times
Hi Pere,
I had to insert NOPs after some of the writes to $ff41, but other than that your assembly program works ok for me.
(The sound chip needs 8 cpu clocks to process each command. LDA #n STA ,X is only 6 cycles and a bit too fast)
Hi Stew,sorchard wrote:Hi Pere,
you are right, the music chip needs some 24 cycles at 4MHz so it is aprox 6 cycles at 0,89MHz
IN Basic this doesn't matter due to the low execution speed of Basic but when it comes to ASM
it is really important timing the commands.
As after a STA $ff41 there is a LDA #nnnn it needs two NOPs before it (2+2+2 cycles)
And where LDA ,X is used, a single NOP is enough (2+4)
I corrected this in my source code and still the same 'wrong sound interruptions'
I run XRoar on Windows 10, are you using this awful OS too?
Don't know what parameters could be changed for XRoar to process sound in this case.
thanks
