Hi folks!
As you may know, I'm working in a utility for converting wav files into cas files. I think my program is nearing a nearly usable state, and that raised a question.
I was debugging my program with my wav dump of "Dragon Selection II", and when I managed to convert it to .cas, I noticed that the contents of the tape are repeated three times on each side.
What would be the course of action here? Should I upload the cas file with the repeated info (which is really what it's on the original tape), or should I just keep one of the three copies?
Question on tape dumping
Re: Question on tape dumping
In a case like this, I would create a cas file with a just single copy of the program. I would then put a note in the zip archive with the cas file to explain that the original tape came with three copies.
BTW, I'm looking forward to the release of your wav2cas utility.
So long as the copies are identical I would follow Steve's suggestion. Just be careful that the tape is not like Planet Invasion or Donkey King where there are differences between the two or three programs recorded on each side of the tape.
Me too!BTW, I'm looking forward to the release of your wav2cas utility.
![Laughing :lol:](./images/smilies/icon_lol.gif)
I need to complete the cas to wav process and then just make the wav translation process independent of the frequency of the wav file, so you don't have to convert the file.
Hopefully this weekend or next week, I'll release a version so you can test it. As usual, feedback will be welcome!
