I've broken Xroar on my Mac ...
Hi all - and a Happy New Year! ...
Well, I've had the wonderful Xroar running perfectly on my Mac for ages, using Ciaran's precompiled 0.32 version. I recently downloaded the source for 0.33.2 so I could apply Tormod's nx-32 patches, and that compiled and ran just fine - or so I thought.
Both versions are now exhibiting the same bug - when I use the file menu (or command-L) to load a file, the emulator appears to freeze (cursor stops flashing, no input is echoed on the screen) after the file dialog closes. It doesn't matter what I load - or even if I load anything at all (just clicking cancel is enough to make this happen).
I'm presuming that I've mucked up SDL somewhere. I did a 'brew install sdl' as per the instructions, and have version v1.2.15. If I run 'xroar -debug-ui -1', then I can see the keyboard inputs into SDL, even after I've done a load and the emulator has 'frozen'.
A load via the command line still works perfectly.
Any thoughts much appreciated!
Tony
Re: I've broken Xroar on my Mac ...
Sounds weird. I don't have a mac to test this on any more (well I do - an old PowerPC one - but it's hidden somewhere since moving house - and it's running 10.4, so unlikely to prove anything). Is it just video that freezes? eg, if you type "SOUND 1,1" blind, is it still doing stuff?
Ah, a good test - yes, the video has stopped, it still makes sounds.
Well, I've no way to test this, but you could try getting it to force reinitialise the SDL window each time it fires up a modal dialogue box. Kludge alert! In src/macosx/filereq_cocoa.m, add this towards the beginning:
#include "xroar.h"
Then this line before the "return" in both load_filename and save_filename:
xroar_set_fullscreen(0, video_module->is_fullscreen);
Thanks for the kludge - alas, that didn't seem to fix it, but my workaround here has. I noticed that if I do command-F twice (fullscreen and back), I get the screen back. And now, in one of those mysterious 'honestly, I didn't dream this bug' moments, the problem just seems to have disappeared. So now I can't even replicate the issue - let's hope it's gone for good. Many thanks for your help, Sixxie!
