XRoar 0.32 released
Re: XRoar 0.32 released
pser1 wrote: Just to let you peek that file, I include it hereunder. The ROM names are the ones we could find on the archive, but it is simple to change them to acomodate each one's ROM names
machine dragon64
	machine-desc Dragon64 (last)
	machine-arch dragon32
	extbas d64rom1V31.6r
	altbas d64rom2V31.6r
	machine-cart dragdisc
	ram 32
Looks like this entry is a mistake and should be configured as follows?
machine dragon64
	machine-arch dragon64
	ram 64
@sixxie: IMHO you should add information about linux binaries on the Windows/MacOS download list.
I found the information in a old post:
sixxie wrote:There is a debian testing package for amd64 - apt source here:
deb http://www.6809.org.uk/debian testing main
deb-src http://www.6809.org.uk/debian testing main
btw. why not add the ladt .deb package as a download link into the table beside Windows/MacOS ?
In the following cases I'm having problems loading cassette programs in the latest version of XRoar (xroar-snap-2014-27552-w32). I've run tests on various non-snap versions (all Win32) to find the last full version where the problem does not occur.
1. If I load a program in one machine profile (say PAL Dragon 64) then switch to another machine (say Dragon 32) any further attempt at loading a program fails. If I switch machines without attempting to load a program in the first profile then I have no problem loading programs in the second profile.
Version 0.29.5 is the last full version where I can load, switch, and load again.
2. When a Dragon is in 64 mode I find machine code .cas files fail to load. Both m/c wave files and BASIC (.cas) programs load but are slow loading, despite 'fast loading' being enabled.
Version 0.28.1 is the last full version where m/c .cas files load in 64 mode.
Mdemon101
Post by Mdemon101 »
Is Xroar Mac compatible?
Mdemon101 wrote:Is Xroar Mac compatible?
Yes, there are mac builds, but I don't tend to get around to doing builds of the snapshots.
I tried xroar_0.32+33SNAPSHOT20140623081438+0100-1~testing_i386.deb and get this:
Module init: GTK+-2 UI
Module init: GTK+-2 file requester
Module init: GtkGLExt video
(xroar:11662): GdkGLExt-WARNING **: Window system doesn't support OpenGL.
Module shutdown: GTK+-2 file requester
Module shutdown: GTK+-2 UI
Does your system not handle OpenGL at all? You might have to just revert to using a manual build using SDL.
It's my error... I used virtualbox...
With may daily used LinuxMint Debain Edition i have no running opengl... But then i found a missed packages related to OpenGL... After install, XRoar and the test program glxgears worked, but only in fullscreen :(
With a second test box with a fresh Linux Mint 17 all works well :?
Ah cool. In the meantime I pushed an update that includes the SDL option.
jedie wrote:After install, XRoar and the test program glxgears worked, but only in fullscreen :(
This is fixed, by deactivating "3D acceleration" in VirtualBox :)
