Artifacting on the Tano Dragon
When a black & white PAL dragon game gets played on the Tano Dragon, will it always show artifact colours, or is it something that needs to be enabled through programming?
Re: Artifacting on the Tano Dragon
The artifacting is entirely down to the display TV/monitor, there's nothing to set on the Dragon to start the effect.
The effect will show automatically if you use the RF cable or with a composite connection. The Tano Dragon has a monitor port at the back, which I think is composite.
It doesn't show up if you use an RGB connection, but only the CoCo 3 has one of those.
Thanks for your answer.
