Dragon emulator written in Python ???
Re: Dragon emulator written in Python ???
v0.3.0 is released: https://pypi.python.org/pypi/DragonPyEmulator/0.3.0
Some changes:
Change Display Queue to a simple Callback
Reimplement Multicomp 6809 and SBC09
Many code refactoring and cleanup
(from: viewtopic.php?f=7&t=4760&p=11891#p11889 )
jgerrie wrote:Been having trouble "injecting" the source into the Coco2b. Errors out with:
"OverflowError: unsigned 1-byte integer is greater than maximum"
Confirm, the bug...
It happens, if line numbers are more than $ff :oops:
Will fix this...
EDIT: Is fixed with: https://github.com/jedie/DragonPy/commi ... 658f505846 :D
today, i have split the 6809 CPU code into a separate project:
I add a example how to use MC6809...
See: https://github.com/6809/MC6809/blob/mas ... ple6809.py
I just release a new Version of MC6809:
https://pypi.python.org/pypi/MC6809
I have switch to "nose" to run unittests and cleanup the test code.
How the test run looks like, can be seen here: https://travis-ci.org/6809/MC6809/jobs/74993785
Which code parts are covered from tests, can be seen here: https://coveralls.io/github/6809/MC6809
Status Update:
I worked on the install procedure: Now the ROM file will be downloaded, extracted and cached on-the-fly. (All with SHA-1 checksum compare)
Now it's easier to install, see README:
I add a "starter GUI", look like this:
And i fix the "freeze" Bug, in some situations after enable the realtime mode (speed limit)...
See also the "History": https://github.com/jedie/DragonPy#history
