Dragon emulator written in Python ???
Re: Dragon emulator written in Python ???
I implement more ops and the Indexed addressing modes: https://github.com/jedie/DragonPy/blob/ ... 09.py#L672
think there must be exist a few bugs :(
Current output:
init 16384 Bytes ROM (0x8000 - 0xc000)
Read 16383Bytes from d32.rom into ROM 0x8000-0xbfff
init 32768 Bytes RAM (0x0 - 0x8000)
$b3ba *** new op code: $8e (LDX_immediate)
$b3bd addressing 'immediate word' value: $401 	| $b3bd: $a000-$bfff - CoCo - Color BASIC ROM
$b3bd LDX immediate: set $401 to index X |: $b3bd: $a000-$bfff - CoCo - Color BASIC ROM
$b3bd *** new op code: $6f (CLR_indexed)
$b3bf indexed addressing mode: postbyte: $83 == 10000011
$b3bf indexed addressing mode ea=$3ff
write $0 to: $3ff: $3ff - D64 - %PRNSEL% selects default printer port 0x00 Parallel, non-0x00 Serial (0x00)
$b3bf *** new op code: $30 (LEAX_indexed)
$b3c1 indexed addressing mode: postbyte: $1 == 00000001
$b3c1 LEAX indexed: set $402 to index X |: $b3c1: $a000-$bfff - CoCo - Color BASIC ROM
$b3c1 *** UNKNOWN OP $26
Opcode $26 seems to be a wrong value. Because i didn't find any information about this value.
I also didn't know where to start. Now i simply set the programm counter to $b3ba, see: https://github.com/jedie/DragonPy/blob/ ... 09.py#L398
Didn't know if this makes any sense...
jedie wrote:$b3c1 LEAX indexed: set $402 to index X |: $b3c1: $a000-$bfff - CoCo - Color BASIC ROM
The comment should rather annotate $402 than $b3c1...
$b3c1 *** UNKNOWN OP $26[/code]
Isn't that BNE? Those opcodes seems to almost have burned themselves into my memory from childhood :)
From a quick look at your cpu6809.py it seems that you have only implemented a few opcodes. How do you think it can work if you don't fill them in?
The CPU looks at the reset vector at $fffe when it is reset. On the Dragon/CoCo $fff0-$ffff is a mirror of $bff0-$bffe (I think the SAM does this). The emulator should do it the same way to work correctly with any ROM.
Get an overview of the 6809 command set. See "Inside the Dragon" for a start, then "Programming the 6809" for a more complete reference.
Note also how the 6809 opcodes are nicely and systematically laid out, and orthogonal with respect to addressing modes: Most opcodes work for all similar registers, and most address modes. So you have for instance LEAX, but also LEAY, LEAS and LEAU. And you have a sequence with opcodes on A, with the equivalents for B just offset with a multiple of 16: LDA # = $86 and LDB # = $C6 etc.
tormod wrote:From a quick look at your cpu6809.py it seems that you have only implemented a few opcodes. How do you think it can work if you don't fill them in?
Yes, i implement the lastes "unknown" opcode... step-by-step... Maybe later i can merge some of the code...
tormod wrote:The CPU looks at the reset vector at $fffe when it is reset. On the Dragon/CoCo $fff0-$ffff is a mirror of $bff0-$bffe (I think the SAM does this). The emulator should do it the same way to work correctly with any ROM.
On which information does the SAM mirrored some memory segments? Does this exist somewhere in the ROM?
tormod wrote:Get an overview of the 6809 command set. See "Inside the Dragon" for a start, then "Programming the 6809" for a more complete reference.
Thanks. There exist many information around the 6809 and i have a few references... Too many references ;)
btw. Seems that this CPU used in some university for teaching, too.
tormod wrote:Note also how the 6809 opcodes are nicely and systematically laid out, and orthogonal with respect to addressing modes: Most opcodes work for all similar registers, and most address modes. So you have for instance LEAX, but also LEAY, LEAS and LEAU. And you have a sequence with opcodes on A, with the equivalents for B just offset with a multiple of 16: LDA # = $86 and LDB # = $C6 etc.
Yes, but code merging and refactoring is a later step for me...
EDIT: Opcode 0x26 seems to exist, see: https://github.com/jedie/XRoar/blob/mas ... 1177-L1188
jedie wrote:Opcode 0x26 seems to exist
Implemented with https://github.com/jedie/DragonPy/commi ... 846#L0R902
I started to adoped the complete branch_cond() stuff from: https://github.com/jedie/XRoar/blob/mas ... #L546-L570 but it seems that there is some mismatched with information from "The 6309 Book"...
EDIT: Oh fuck :oops: I have mismatch 6309 and 6809 :roll:
With https://github.com/jedie/DragonPy/commi ... e246b934a7 i hope to fixed the indexed addressing modes.
I have now looked into "Programming the 6809" and here: http://www.maddes.net/m6809pm/sections.htm#sec2_2_5_1
Some commits later: https://github.com/jedie/DragonPy/compa ... .e06708126 looks the output like this:
$b3ba *** new op code: $8e (LD16)
$b3bd get_ea16(): ea: $401 accessed by immediate_word (op:$8e) | $401: $400-$5ff - Default Text screen
$b3bd LD16 load register index_x from $401 | $401: $400-$5ff - Default Text screen
$b3bf indexed addressing mode ea=$3ff | $3ff: $3ff - D64 - %PRNSEL% selects default printer port 0x00 Parallel, non-0x00 Serial (0x00)
**** write $0 to $3ff - mem info:
$0: $0 - BREAK message flag - if negative print BREAK
$b3c1 *** new op code: $26 (BNE)
$b3c2 BNE: set pc to $b3c4: $b3c4: $a000-$bfff - CoCo - Color BASIC ROM
$b3c4 *** new op code: $ba (ORA_extended)
$b3c7 addressing 'extended indirect' value: $776f | $776f: UNKNOWN
$b3c7 ORA extended: set A to $776f ($0 | $776f) | $776f: UNKNOWN
**** Set cc overflow from 8-bit accumulator A, value: $776f
^^^^ Value for A truncated to $6f
$b3c7 *** new op code: $80 (SUBA_immediate)
$b3ca addressing 'immediate word' value: $9f19 | $b3ca: $a000-$bfff - CoCo - Color BASIC ROM
$b3ca ORA extended: set A to $-9eaa ($6f - $9f19) | $9f19: $8000-$9fff - CoCo - Extended Color BASIC ROM
$b3ca *** new op code: $a6 (LD8)
$b3cc indexed addressing mode: postbyte: $2 == 00000010
$b3cc get_ea16(): ea: $404 accessed by indexed (op:$a6) | $404: $400-$5ff - Default Text screen
$b3cc *** UNKNOWN OP $43
But makes no sence, that the 8-bit accumulator A should be set to $776f (a value in 16-bit range) ?!?
I have made the accumulators as a object and check the overflow in get methods, see: https://github.com/jedie/DragonPy/blob/ ... ors.py#L20
Don't know if that's the right way.
I also seperate the "condition code register bits" here: https://github.com/jedie/DragonPy/blob/ ... ter.py#L43
There are some FIXME comments, because i think is doesn't work as aspected.
In a unittests, a faked additional, the overflow flag would not be set.
        a = 0xff
        b = 1
        r = a + b
        self.cpu.cc.set_NZVC8(a, b, r)
        self.assertEqual(self.cpu.cc.N, 0)
        self.assertEqual(self.cpu.cc.Z, 1)
        self.assertEqual(self.cpu.cc.V, 1) # FIXME
        self.assertEqual(self.cpu.cc.C, 0)
see: https://github.com/jedie/DragonPy/blob/ ... py#L73-L80
Seems that V = 1 if (a ^ b ^ r ^ (r >> 1)) & 0x80 else 0 is not ok?!?
A simple test:
for a in xrange(254, 258):
    print "a=", a
    b = 1
    print "b=", b
    r = a + b
    print "r= a + b =", r, "=",hex(r)
    print "V=",V
    print "(a ^ b ^ r ^ (r >> 1)) & 0x80=", (a ^ b ^ r ^ (r >> 1)) & 0x80
    print
Output:
a= 254
b= 1
r= a + b = 255 = 0xff
V= 0
(a ^ b ^ r ^ (r >> 1)) & 0x80= 0
a= 255
b= 1
r= a + b = 256 = 0x100
V= 0
a= 256
b= 1
r= a + b = 257 = 0x101
V= 1
(a ^ b ^ r ^ (r >> 1)) & 0x80= 128
a= 257
b= 1
r= a + b = 258 = 0x102
V= 1
r = 256 is a overflow, isn't it?
The flag indicates signed overflow:
When you add 255 + 1, you're actually adding -1 and 1, which does not overflow.
Annoyingly, I discovered that the 6809's overflow flag operates differently to, say, the ARM one - which meant my idea of performing all the operations in ARM assembly by shifting things 24 bits left, performing the op, then getting the flags "for free" fell a bit flat ;)
It it's allways a signed overflow? So, adding a number bigger than 8bit to a 8bit register, will not set the overflow flag?
jedie wrote:It it's allways a signed overflow? So, adding a number bigger than 8bit to a 8bit register, will not set the overflow flag?
Well I'm not sure how you'd even do that...
Whatever two 8-bit numbers you add, for the purposes of the overflow flag they're considered signed, i.e., in the range -128 to +127. If the result goes over 127 or under -128, it's an overflow. Of course as it's all two's complement, you can still go and treat the operands and the result as unsigned values and ignore V.
I will start a new implementation.
I hacked some data scraping scripts: https://github.com/jedie/DragonPy/commi ... 5f6e75d903
These script will collect information from:
http://www.maddes.net/m6809pm/sections.htm#sec4_4
http://www.burgins.com/m6809.html
http://www.maddes.net/m6809pm/appendix_a.htm#appA
With the scraper i will create a "python script data file" with all merged data. Something like a poorman database :oops:
Will look like this:
OP_DATA = (
    #### 8-Bit Accumulator and Memory Instructions
        "opcode": 0x0, "instruction": "NEG", "mnemonic": "NEG",
        "desc": "Negate accumulator or memory",
        "addr_mode": 1, "operant": None,
        "cycles": "6", "bytes": "2", "HNZVC": "uaaaa", "category": 0
        "opcode": 0x3, "instruction": "COM", "mnemonic": "COM",
        "desc": "Complement accumulator or memory location",
        "cycles": "6", "bytes": "2", "HNZVC": "-aa01", "category": 0
        "opcode": 0x4, "instruction": "LSR", "mnemonic": "LSR",
        "desc": "Logical shift right accumulator or memory location",
        "cycles": "6", "bytes": "2", "HNZVC": "-0a-s", "category": 0
Then i started to create a "make skeleton" script. To create something like this, automatic:
class CPU6809(object):
    # ADC - Add memory to accumulator with carry
    @opcode((
        0x89, "ADCA", IMMEDIATE, operant=A
        0x99, "ADCA", DIRECT, operant=A
        0xa9, "ADCA", INDEXED, operant=A
        0xb9, "ADCA", EXTENDED, operant=A
        0xc9, "ADCB", IMMEDIATE, operant=B
        0xd9, "ADCB", DIRECT, operant=B
        0xe9, "ADCB", INDEXED, operant=B
        0xf9, "ADCB", EXTENDED, operant=B
    def ADC(self, op, ea=None, operant=None):
        raise NotImplementedError("TODO: $%x ADC") % op
    # ADD - Add memory to accumulator
    @opcode((
        0x8b, "ADDA", IMMEDIATE, operant=A
        0x9b, "ADDA", DIRECT, operant=A
        0xab, "ADDA", INDEXED, operant=A
        0xbb, "ADDA", EXTENDED, operant=A
        0xcb, "ADDB", IMMEDIATE, operant=B
        0xdb, "ADDB", DIRECT, operant=B
        0xeb, "ADDB", INDEXED, operant=B
        0xfb, "ADDB", EXTENDED, operant=B
    def ADD(self, op, ea=None, operant=None):
        raise NotImplementedError("TODO: $%x ADD") % op
    # AND - AND memory with accumulator
    @opcode((
        0x84, "ANDA", IMMEDIATE, operant=A
        0x94, "ANDA", DIRECT, operant=A
        0xa4, "ANDA", INDEXED, operant=A
        0xb4, "ANDA", EXTENDED, operant=A
        0xc4, "ANDB", IMMEDIATE, operant=B
        0xd4, "ANDB", DIRECT, operant=B
        0xe4, "ANDB", INDEXED, operant=B
        0xf4, "ANDB", EXTENDED, operant=B
    def AND(self, op, ea=None, operant=None):
        raise NotImplementedError("TODO: $%x AND") % op
