How to get XRoar to work with games?
lastkill3r
Post by lastkill3r »
Hi! I've just downloaded XRoar and want to play games, but when i start it, there's only chess-like backgriund with lots of "@". What i have to do?
Re: How to get XRoar to work with games?
You have to add the Dragon ROMS to a folder named Roms inside your XRoar folder and name the rom files according the XRoar manual.
For example, if you have XRoar installed in "C:\XRoar", you can put the Dragon 64 roms (named D64_1.rom and D64_2.rom) into the "C:\XRoar\Roms" folder. That should do it.
lastkill3r
Roms like BIOS, or gaemz?
Bios.
lastkill3r
Where to get it?
Get the Dragon 64 roms here: http://archive.worldofdragon.org/archiv ... ?dir=Roms/
Unzip them to your xroar/roms folder and check that the rom names are set as xroar expects.
lastkill3r
I know this, but whats their name?
Download the files Dragon Data Ltd - Dragon 64 - IC17.zip and Dragon Data Ltd - Dragon 64 - IC18.zip and unzip them to your Xroar/Roms folder.
The, rename Dragon Data Ltd - Dragon 64 - IC17.ROM to D64_1.rom and the file Dragon Data Ltd - Dragon 64 - IC18.ROM to D64_2.rom.
lastkill3r
OK, I will try.
lastkill3r
Doesn't work. Still chessboard.
