XRoar Wav Files
chrispoacher
XRoar Wav Files
Post by chrispoacher »
I'm just wondering what the best audio format for wav files is for use with Xroar -tapehack and turn them into .cas files?
I converted a few tapes to stereo 44.1khz wavs and they work fine in MESS but Xroar will not load them at all, wont even change from S to F.
should they be 8 bit 16 bit mono, stereo etc. ? will save me a lot of time experimenting if I know.
Chris Poacher
chrispoacher@yahoo.co.uk
Re: XRoar Wav Files
Anything mono should be ok. Not quite sure why it's not handling stereo, will look.
Edit: ok, the bug is really obvious, I'll fix before the next release!
Re: XRoar Wav Files
Whilst Sixxie fixes that - pop them into Audacity and split the tracks and export as mono
Re: XRoar Wav Files
chrispoacher
Re: XRoar Wav Files
awesome :O)
