Tetris test on a Dragon?
bug2k17
Post by bug2k17 »
Any of you guys able to test my version of Tetris on a real Dragon 32? I haven't got round to fixing mine, only my Coco1 is running at the moment.
tetris.dsk
(157.5 KiB) Downloaded 6 times
tetris.cas
(43.74 KiB) Downloaded 6 times
Re: Tetris test on a Dragon?
I don't have convenient 32 set up to test on but it runs under emulation.
Nice sounds and particle effects!
There are a lot of keypresses it won't recognise though - while reconfiguring the controls and while entering your name. In CoCo emulation it was still picky about the controls, but I was able to enter my name properly.
Anyway, I got 19300.
bug2k17
Post by bug2k17 »
I'll check scan routine, default keys should be < left > right / down c rotate <space> drop, I only tested a few other on the bottom row and arrows. m on the title screen mutes the music. There is likely some logic bugs with the block checking too.
I didn't notice anything obviously wrong with the gameplay...
The keys that aren't recognised for configuration definitely include (1 9 A I Q Y CLEAR) (which share a column. or row, depending on how you look at it) and some others which you might be reserving including (UP C K S SEMICOLON).
bug2k17
Post by bug2k17 »
I was checking the same columns, so missing others. I've edited the first post (I think!) can you try this one.
Will do.
Meant to say I tried it on a real Dragon 64. 15120...
Yep, the new version lets me enter my preferred keys. No joy on the high score table though.
bug2k17
Post by bug2k17 »
Is it the high score table on the real dragon that isn't working? which keys work/don't work? Just testing in xroar all upper and lower case letters work. I think I may have tried to be too clever and guess which type of keyboard is used based on the first few key pressing used, perhaps just checking the rom would be better.
bug2k17 wrote: ↑Tue Sep 22, 2026 6:11 pm Is it the high score table on the real dragon that isn't working? which keys work/don't work? Just testing in xroar all upper and lower case letters work. I think I may have tried to be too clever and guess which type of keyboard is used based on the first few key pressing used, perhaps just checking the rom would be better.
Yeah real Dragon 64 - no dice typing 's' or 'x'. It was ok with 'i' though.
bug2k17
Post by bug2k17 »
Try this updated version, has different masking for the dragon keyboard transform.
