Shard's Software Shaper
daftspaniel
Post by daftspaniel »
I am looking for Shaper if anyone has got it into a form for an emulator.
Used to spend hours making sounds with that program :D
Thanks,
Davy
munkeyboy
Re: Shard's Software Shaper
Post by munkeyboy »
Thank's for reminding me of this software, some time ago I asked if anyone had a copy but with no luck.
A friend of mine has just uncovered some tapes in his loft and has told me that Shaper by Shard's is one of the titles :D .I will pick them up next week, and hopefully it will still be a working copy. If it is I will upload as soon as I can.
Gareth
munkeyboy
Post by munkeyboy »
Here is the .wav file of Shaper as promised, I have tried it on Xroar and it loads :P
I tried to convert it to a .cas file but I had no luck, I seem to be living up to my name on this forum :roll:
I will hopefully be uploading some more soon, and if this wav to cas software caters for numpties like me then that is the format I will try to use.
Cheers, Gareth
Forgot to add that it loads with CLOAD and just follow on screen instructions.
Shaper by Shards.zip
(1.18 MiB) Downloaded 797 times
Thanks, Gareth! 8-) I have just uploaded a .cas file (created from your original wave file) to the Uploads section.
daftspaniel
Thanks guys - this is excellent. Look forward to having fun with Shaper again :D
